difference in engines
The forum for contacting Mazda directly with queries, comments, questions & suggestions.
Postby roche88 » Thu, 14 Jan 2010 12:42 +0000
im hearen a rumour that the mazda mx5 mk1 1.6 has the same engine as the 323 is this correct?or is there small difference between them?all replys welcome
roche88
Re: difference in engines
Postby Steve » Thu, 14 Jan 2010 12:50 +0000
It has the same block as the 323 turbo, but the pistons are higher compression & rods are lighter. </nerd>
Postby CashelMX5 » Thu, 14 Jan 2010 12:54 +0000
Only you would've had the answer to that one Steve - good on ya! :thumright:
Postby roche88 » Thu, 14 Jan 2010 1:10 +0000
but say could u use the raidiator for mx5 off the 323?
roche88
Postby franksm » Thu, 14 Jan 2010 2:46 +0000
Nope, the mountings are different what with the 323 being FWD etc
Postby roche88 » Thu, 14 Jan 2010 2:49 +0000
so is there a nother raidiator i could use?
roche88
Postby franksm » Thu, 14 Jan 2010 2:54 +0000
Return to Ask Mazda...
