lsdwould anyone here be able to help me fit the lsd i got for my car maybe sometime next week or show me/talk me through it?,id have a go at it but dont want to mess it up,is it a big job?
Its not really a huge job mate. Are you replacing a 1.6 with a 1.6 lsd. if so you don't need to swap out the half shafts. I did mine myself. You need good access under the car (axle stands or blocks) and a decent socket set with extension bars.
Guide here http://www.mx5ireland.com/set_tech.htm http://www.cardomain.com/ride/3099765 "When I make a key the on position and push the button, an engine works"
I'm afraid I'm up the walls here at home for the next while.. but feel free to give me a buzz if you get stuck. Its not as daunting as it looks.. hardest bit is getting the diff off/onto the PowerPlantFrame.
thanks ladsok thanks lads il have a go at it next week when i get it back on the road,its a 1.8 lsd going into a 1.8 car.
Same here about the busy thing but feel free to give me a ring.
Who is onlineUsers browsing this forum: No registered users and 6 guests | ||
